Zum Hauptinhalt wechseln
The Grand Prix was updated for 2004 on a revised version of the GM W platform and was unveiled at the 2002 Chicago International Auto Show on February 7, 2002 as the Grand Prix G-Force Concept.
How do I reset security?
car disabled because of security
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Is security Passlock or Passkey? Do you have an owner's manual?
von
It's like body control module not picking up the key but it is intermittent
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Is the security light flashing when you try to start the car? If so, try performing a "Passlock Relearn":
  1. Put the key in the ignition and attempt to start the car, the "Security" light should go on and the car won't crank. Don't move the key to the "off", leave it on.
  2. Leave the key in the on position for around 10 minutes, the security light should eventually go out.
  3. Turn the key to "off", wait 5 seconds, then attempt to start the car. If it starts, you're done! If it doesn't start, to back to step 1 and try again. You may need to repeat this process up to 3 more times to get the car started.
Some things to note:
  • Try to turn off any lights / equipment in the car while you're doing this to avoid killing the battery.
  • This is just a temporary fix and the problem will usually come back. The permanent solution usually requires replacing the sensor in the lock cylinder and possibly getting a fresh key made by the dealer (not a locksmith, you want an authentic GM key from a GM/Chevrolet dealer - they'll make Pontiac keys). I had this problem in my 2001 Monte Carlo, which shares a lot of parts with the Grand Prix, and I had to replace both to get the problem to go away.
War diese Antwort hilfreich?
Bewertung 1
6 Kommentare:
Yes thank you for your information I am away from My books mastermechanic037@gmail.com
von
I can’t get my 2004 Pontiac grand prize to start it was disabled due to theft started l tried the 3 cycle 10 min 5 second thing still wont start I got the security light in dash near windshield to flash again now what will it start when I put key back in ignition
von
I tried the 10 min thing but at that time the light wasn’t flashing in dash but module above center console says disabled due to theft system can I disconnect positive and negative cable for a period of time reconnect them and then be able to start car normally
von
Any help would be appreciated
von
Mines doing the same things I tried everything they said and it's still doing the same thing help please
von
1 weiteren Kommentar anzeigen
Anyone else figure it out I have the same problem tried the on position for 10 minutes thing still didn't work help please
Bewertung 0
1 Kommentar:
Please don't assume anyone knows what you're driving. Make, model, year, if GM - is your factory antitheft Passlock or PassKey? Is there an aftermarket alarm system?
von
04 pontiac grand prix v6 3.8l paskey 3 without theft lights blinking in dash or window just reading starting disabled due to theft system no aftermarket security wtf
Bewertung 0
1 Kommentar:
How do you know the antitheft system disabled starting without any indicator flashing or blinking to alert you of the antitheft system disabling starting? Your '04 grand prix is 21 yrs old. Is the battery fully charged? Is the starter worn out. Are battery cables clean, not corroded, loosely connected? Are main grounds clean (battery negative to chassis and chassis to engine block), not corroded, loosely connected?
von
Antwort hinzufügen
Wendy Rudquist wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 57
Letzte 30 Tage: 163
Insgesamt: 5,747
