Zum Hauptinhalt wechseln
Apples absolutes Flaggschiff-Smartphone für 2021. Das iPhone 13 Pro Max hat ein 6,7" ProMotion OLED Display, ein neues Drei-Kamera-System auf der Rückseite und 5G. Es ist der Nachfolger des iPhone 12 Pro Max und erschien am 24. September 2021.
iPhone 13 Phone lost cell service. After a reset it will not activate.
Phone lost it's cell service and the bars went to waving at me. Preformed the update 16.2 then it would not verify the update. I managed to update the phone to 16.2 from ITunes, still no cell service. Apple had me reset the phone and now it is stuck in the setting up a new phone start up. It will not activate. The wifi work but the cell side doesn't. Anyone else with this problem?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
The phone is not possible activate becouse there is missing imei number. Is common issue on this models starting on iphone X. This models have "sandwich" motherboard(2boards soldered together) on the lower board is all signál circuits like wifi baseband nfc etc. When is lower board lost contact with upper board it make this problém. For permanently problem solve is need swap the lower board. When wifi is work can be "only" power controller for baseband. Anyway, nothink what you can do in home.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
You mean swap the lower board on top and the upper board down
von
So how can I fix my iPhone with my din saying no service
Bewertung 0
Antwort hinzufügen
Scott wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 700
