Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2010 / 3,06 & 3,2 GHz Core i3 oder 3,6 GHz Core i5 Prozessor
screen is on for a bit then turns off, works with external display
I recently got an iMac in a lot, it works for a bit 30 seconds or less, then the main display will turn off and won't come on, I've tried to reseat connectors pram reset and everything else. any ideas?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
@connorsmig25744 it will turn off or it will turn dark? If it turns dark it's an issue with the backlight :-)
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Honestly, that sounds like something is wrong with either the display itself, or the connection between the display and the SOC. You should try examining it to check for any signs of damage, and should probably take it to a repair shop to perform diagnostics.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Will do tbh idk if i plugged it in right
von
Antwort hinzufügen
Connor Smigielski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 27
Insgesamt: 171
