Zum Hauptinhalt wechseln
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Computer crashes to a blank green screen.
I’ve recently built my first pc and for the 1st day it was running great. Yesterday and today hasn’t been the same. After only a few minutes of running the pc will crash in to a blank green screen. Any tips? Anyone else ever have this problem?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hi @koithyboi,
What is the make and model number of the motherboard and the GPU card?
Try disconnecting the SSD (HDD?) and check if you can get into BIOS OK with a display.
Have you checked the monitor's working OK i.e. can you view the OSD menus?
von
Einen Kommentar hinzufügen
1 Antwort
What operating system is it running on?
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Was running windows 10 when it started. Upgraded to windows 11 only for it to crash more often
von
It could be a bios issue or corrupted files, maybe you should upgrade your drivers, it could be a monitor issue too
von
Antwort hinzufügen
koithyboi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 65
