Zum Hauptinhalt wechseln
The Razor E300 is one of the most popular electric kick scooters in the world.
Why is my scooter running when turned on
When the power button is pushed the scooter starts running without using the throttle
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Disconnect the throttle then turn it on. If it doesn't try and move then the throttle is faulty.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank u I'll try that when I get home but wat if it still moves ?
von
@cheriebelt then the control box has failed and needs replaced. You could also check for shorted components inside the box or possible damage to the throttle or cable itself if its been dropped or accident you will need a multimeter.
von
Antwort hinzufügen
Cherie belt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 206
