Zum Hauptinhalt wechseln
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 Fragen Alle anzeigen
Random Disconnects On PC After 1 year
The computer keeps randomly disconnecting im not sure why
Tested the Ethernet cable and that's good. Happens on hotspot, Wifi & ethernet.
Updated everything including motherboard and still happens. Only device on network this happens too
My PC Build
  • CPU: AMD Ryzen 7 5800X 8-core
  • CPU cooler: NZXT Kraken X53?
  • Motherboard: MSI X570 Gaming Edge Wi-Fi
  • Ram: Trident G-skill F4-3000C16D-16GTZR x2
  • SSD/HDD: Samsung 980 Pro 1TB
  • GPU: AMD Radeon RX 6900 XT
  • PSU: EVGA 1300XT
  • Chassis: NZXT H7?
  • OS: Windows 11
  • Monitor: ASUS TUF VG27A
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
9 Kommentare
Hi @alexduncan10584,
How do you get it to reconnect after it has disconnected?
Does it only disconnect when you're connected to the same website or any?
Check in Event Viewer for any Critical, Error or Warning events that may be logged at the time the PC disconnects online.
Check in Device Manager > right click LAN network adapter (and WLAN adapter as well) > Properties >power management and check that the option to turn off the device is not enabled
von
Tithe disconnect is extremely brief it happens to the point windows doesn’t know it’s happening. Hardly shows in a ping test
von
@alexduncan10584
If it's that brief, how is it affecting online use?
Does it also occur on other devices that are connected to the same Ethernet port (or if WiFi), in the exact same location as the PC? There may be some kind of interference occurring (EMI?) which affects the data signal and the adapter has to re-train the connection between the PC and the modem
von
Call of duty and other game services notice it
von
@alexduncan10584
Was editing comment when you answered, see update
von
4 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
internet service provider messed up my settings on my modem
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Did they say what setting (or at what end - yours or theirs) they changed?
It seems very strange that changing modem settings would have affected only one device when you tried other devices connected to the same modem and had no problems when playing the games you mentioned, especially when trying both Ethernet (using the same port) and WiFi.
von
@jayeff no they didn't want to say besides changing settings on the modem
von
@alexduncan10584
Did they say why they changed them?
von
Hilfreichste Antwort
Here are some possible reasons why your PC keeps randomly disconnecting:
  • Software issue: There could be a problem with your operating system or with a third-party application. Try running a virus scan, or try disabling any unnecessary applications that are running in the background.
  • Interference: There could be something interfering with your wireless signal, such as a microwave oven or a cordless phone. Try moving your router to a different location, or try using a wired connection instead of wireless.
  • Outdated drivers: If your network adapter drivers are outdated, it can cause your computer to randomly disconnect from the internet. You can update your network adapter drivers manually or automatically.
If you've tried all of these troubleshooting steps and your computer is still randomly disconnecting, you may need to contact your ISP or a computer technician for further assistance.
Bewertung 1
1 Kommentar:
So it turns out it was my ISP. They changed some settings obviously wont tell me. But its fixed now
von
Have you tried putting in a PCI network card? If your built in network card is faulty, that could solve the problem
Bewertung 0
2 Kommentare:
Bought a $15 one with no change
von
@alexduncan10584 Oh ok. Then try what @jayeff suggested.
von
Antwort hinzufügen
alex duncan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 135
