Zum Hauptinhalt wechseln
Released April 2022 as part of the Dell 7000s series of laptops. Comes both in a standard laptop model and a convertible folding tablet model.
recovering abandoned laptop, bitlocker issue
I've inherited a Dell Latitude 7430 with W10 that has Bitlocker installed. I have no documentation at all, so no recovery passwords.
I want to format and re-install Windows with no Bitlocker. I've gone to BIOS and made the USB with the install the first boot option, and that works. But when following the prompts to install, when I am asked what drive to format the option area is empty. It suggests loading drivers.
I have gone to Command Prompt and am able to see the C: drive and it's four partitions there.
I can see the Bitlocker ID in Command Prompt but the password does not display.
I'm at a loss how to get Windows to install. Help? Please?
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Normally you should be able to remove Bitlocker encrypted partitions through this menu, but perhaps it's being a bit stubborn. Let's try this instead.
Instead of clicking the install Windows options in the Windows installer menu, click repair your computer instead. From here click Advanced options and get to a Command. Hopefully it will not prompt you for any passwords or keys as part of this process. it usually doesn't when you're doing so from USB media, I never know. Once it opens, type diskpart and press enter.
Once your the computer launches diskpart in the command line window you'll get the diskpart> prompt.
Enter list disk The command will output a list of the current disks connected to the machine, including your USB drive. Your boot disk will probably be disk0, but whichever disk it is select that disk by typing select disk N where N is the number of your internal disk in the output.
I might try typing clean here, and see if that alone works, but it may not. If it doesn't you can select the individual partition and delete that by typing list partition then select partition N in the same way you did for the disk, where N is partition number you want to delete. Then type delete partition override. If you don't get any errors, type exit, restart the computer back into your install USB and see if that helped.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kelly Myers wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 29
Insgesamt: 407
