Zum Hauptinhalt wechseln
Toy quadcopter with camera, controlled over Wifi by smartphone.
What is the 3-Axis Accelerometer Specification / Part Number
The AR Drone breakdown is excellent, thank you. I have just one question.
Do you have the specification/part number for the 3-axis accelerometer which I presume is one of the components on the Navigation Board.
Many thanks
Mick (Masters Student)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
check this "For the inertial guidance system, ACAL recommended a Bosch BMA150 3-axis accelerometer which works in conjunction with a 2-axis gyrometer and a 1-axis yaw gyrometer to provide the data for the auto-pilot. Initially. the AR.Drone used a QFN-packaged accelerometer, but ACAL suggested migrating to the LGA-packaged BMA150. This reduced both the power consumption and cost," from here. the datasheet is available here. Just in case you need the navigation board, is is available at places like this. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Mick Nadin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 1,794
