Zum Hauptinhalt wechseln
Repair information for water guns, which are toys designed to shoot water.
Why wont my water gun shoot
When I pull back the trigger on the x shot zuru hydro hurricane water gun it dosent shoot
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
I orWA shot foam wanted gun and it doesn’t shot and came torn
von
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
Insufficient Water Pressure:
One of the primary reasons your water gun may not be shooting is due to insufficient water pressure. Before taking any further action, make sure the water reservoir is filled to an appropriate level. Additionally, check if the pump mechanism is working correctly. Insufficient water pressure can be caused by a blockage in the nozzle or a malfunctioning pump.
To fix this issue, start by ensuring the nozzle is clear of any debris or obstructions. Use a small tool or a pin to gently remove any clogs. If the problem persists, disassemble the water gun and inspect the pump mechanism. Look for any signs of damage or misalignment. In some cases, lubricating the pump may resolve the issue. Use a silicone-based lubricant to ensure smooth operation.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
I have taken it all ap
von
I have taken this all apare and cannot get the pump to work. I have a very disgruntled 9 year old who bought this and cannot play with it. Please help me out here. Nancy Lilly
von
Bought new or second hand?
von
Check for leaks, make sure the gun is filled, ensure pump is functioning properlhy, remove air pockets by tilting or shaking the gun. Make sure the trigger not sruck, look for any visible dmaaged or brokened parts
Bewertung 0
Check for an air lock - a bubble of air that is preventing passage of water through the gun by draining the whole thing. Also, if your gun froze over the winter the hoses or other parts could have cracked. I take mine apart using a screwdriver to see what is going on inside. I had one gun that the hose was molded by a stop that would normally prevent the gun from shooting but allow water to pass through when not depressed It stopped working cause the plastic stayed closed even when the stop was not depressed. Was not worth the effort to put in new hosing.
Bewertung 0
Why water is no not coming from
my water pistol
Bewertung 0
It could be many reasons, easier go here https://electricwaterguns.store/ and buy a good one, I got my one from there and it is pretty cool
Bewertung 0
Because u did not fix it properly
Bewertung 0
Antwort hinzufügen
NotYappy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 75
Letzte 30 Tage: 282
Insgesamt: 7,263
