Zum Hauptinhalt wechseln
The Samsung RF263TEAE is a 25.5 cu. ft. refrigerator with a twin cooling plus system, power freeze and power cool options, LED lighting, spill-proof shelves, and an ice master ice maker. Its dimensions are 33 3/4 inches deep without handle, 66 7/8 inches height to top of case, and 35 3/4 inches wide.
Ice master is no droping ice from door
ice master syoped wotking from the door, is dropping to freezer bin.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If ice is going into the freezer bin, then the mechanism that pushes the cubes out is not working.
There are a number of things that might cause this. The first thing would be the switch mechanism the turns the dispenser on.
I can't tell you how to get at it and check it, but that is where to start.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Renee Waage -Younger wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 113
