Zum Hauptinhalt wechseln
Ein Mittelklasse-Smartphone von Samsung, das 2019 veröffentlicht wurde und über eine verbesserte Kamera gegenüber dem A50-Modell verfügt.
What to do if Display Touch is not working of Samsung galaxy A50s
What to do if our Samsung galaxy A50 s mobile display touch is not working
Ist dies eine gute Frage?
Bewertung 3
5 Kommentare:
nature problem
von
Go to the nearest technicians
von
@louisdaniel you are missing the point of this website. We are trying to empower people to fix their own devices and to safe their hard earned money, not send them to a repair shop.
von
Fingerprints not working
=== Update (05/28/24) ===
von
Help me ? I went amna gara Jamoon jiraa hayyaa
von
Einen Kommentar hinzufügen
2 Antworten
some troubleshooting questions to ask to hopefully narrow this down. and either I or someone else can give you the answer.
  1. is it getting power and or does it seem to have any power related issues?
  2. is the device showing signs of life? when the proper button is pushed does it light up? (whatever that may be) and does it seem to have solid power?
  3. does the device sound, feel, and look as it should?
  4. are there other things going on? does the display look different? anything that happened at the same time as touch not working? any physical damage to the display? (my experience with samsung displays is if it’s damaged, it may work now, but it will eventually fail.)
  5. describe doesn’t work: doesn’t work can be as simple as not responding to touch at all. (could assume but i’ve usually made troubleshooting mistakes when i do that) it’s best to have as much info as possible to get the best picture of what you’re experiencing.
  6. (ties into previous question) has the device recently or anytime in the past come in contact with water?
  7. this can be dropped in the ocean, to being in the bathroom while taking a hot shower (steam damage) to even living in high humidity areas.
there are tons of other questions to ask. but these sets are a good place to get started.
as stated earlier I don’t like to fill in the info myself for these questions as that leads to poor troubleshooting and won’t help you.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
My phone Displays damage
von
@pawanbaheti I would always do a soft reset first. Just to make sure that it is not a software issue. Press and hold the Power button and Volume down button, down simultaneously for more than 7 seconds. You will feel it vibrate when your phone restarts.
I that did not resolve anything it could be time to replace the digitizer, which is part of the display assembly. To replace the LCD use something like this video
If even with a new display your touchscreen still does not work, your phone may need a board level check. SOmething like this flowchart will help with that.
To find the components to check use your search function on your PDF reader to locate them from this Component Layout
Bewertung 0
Antwort hinzufügen
Pawan Baheti wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 23
Insgesamt: 1,195
