Zum Hauptinhalt wechseln
Reparatur- und Demontage-Anleitungen für das Nokia G22 Android Smartphone. Das Gerät wurde im März 2023 veröffentlicht. Es kann durch seine Modellnummern TA-1516 oder TA-1528 identifiziert werden.
No Wi-Fi networks showing after about a day of use
So,
after about a day of normal use, Wi-Fi networks stop showing. I can't find any. I try and enable Airplane mode, disable and enable Wi-Fi, but no success. I have to restart for networks to show up again.
Had the phone for about a month, and I think the problem came after updating to latest system version ... Android 12, Security update on 5th June 2023.
Any suggestions?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Yes, you need to factory reset your phone, just add any important pics or contacts ect. To your email account to be saved first.. somewhere in update or possibly on accident the wifi Manger software has gotten deleted.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Hello Chris,
thank you for your answer. Since I'm not super proficient in Android and I was wondering if there is a way to confirm that missing Wi-Fi manager software is at the root of this cause?
I can manually add and remove Wi-Fi networks, QR code scan and add also works. Hotspot also works as it should when I turn it on. Only the issue is the randomness of when the Wi-Fi goes dark.
I'm asking this, because it's quite a hassle to do a factory reset, and not being really sure, that this will eventually solve the issue.
Regards,
Darjan
von
Antwort hinzufügen
Darjan Zlobec wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 539
