Zum Hauptinhalt wechseln
Modell A1311 / Ende 2011 / 3,1 GHz Core i3 Prozessor / Nur für Bildungseinrichtungen
Can I take a hard drive from an iMac and boot from it on my MacBook Pr
Can I take a hard drive from an iMac and boot from it on my MacBook Pro to use the iMac as a portable computer?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Can you explain your reason here a bit more.
Are you wanting to access the iMacs data from your MacBook Pro? Either locally or remotely.
Are you trying to setup your MacBookPro as a replacement of your iMac?
You don’t need to remove the drive from your iMac to attain that!
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Screen is destroyed and it’s a work computer and need to work in the interim
von Teilen
@bg234 - Which system has the damaged display? iMac or MacBook Pro and which model as that also effects the answer.
von Teilen
Antwort hinzufügen
bg234 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 279
