What kind of screwdriver is needed to remove the bottom cover
what kind of screwdriver is needed to remove the bottom cover
Ist dies eine gute Frage?
Here's an image taken from this teardown video that shows that the screw is a Torx screw.
(click on image)
The specifications for the 10 screws in the base as shown in the hardware maintenance manual (see p.34) are M2.0 x 6.5mm (9 screws) and M2.0 x 3.5mm (1 screw)
M2.0 = 2mm so that is about a T6 or T7 Torx screwdriver.
War diese Antwort hilfreich?
According to this question, What screwdriver do I need to take off the lower (bottom) case of a and this question which screwdriver do I use? A T5 torx screwdriver is needed. The screw heads in the bottom cover of the Ideapad S340 are reported as being T5 torx screw heads by most users.
A quality small driver kit with several common bit sizes (torx T4,T5,T6, Philips, etc) can be handy; example: Minnow Driver Kit.
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 28
Insgesamt: 178
