Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
5 Kommentare
What part of the motherboard is not working? Can you give more details of the issue?
@kumailkazmi you really need to give us lots more information if you expect some help with this. At minimum we need to know why you think that your motherboard is not working properly. What make and model motherboard? What does or does it not do? What have you checked and what have you tried to fix this?
@amiribnmohammed if you need help with this you want to give us all the information. The fan did not spin is just to vague. What does your computer do? It overheats? Did it overheat because the fan didn't spin? Did you replace the fan? What did you check?
The only logical answer based on your question would be : Replace the fan.
5 Kommentare
von honakrisi
von oldturkey03
=== Update (09/17/23) ===
von Amir Ibn mohammed
von oldturkey03
Yes my mother board is not working
=== Update (10/01/23) ===
Yes mother board not working
von Rambabu kushwaha
