How do I replace the fan in my Presario V6000?
I want to replace the fan in my laptop, it no longer works.
Ist dies eine gute Frage?
Liz, here is the way HP suggests you go about it
"1. Prepare the computer for disassembly and remove the following components:
❏ Hard drive
❏ Memory module compartment cover
❏ Optical drive
❏ Switch cover
❏ Keyboard
❏ Display assembly
❏ Top cover
❏ System board
2. Turn the system board upside down with the expansion port 3
and external monitor port toward you
3. Disconnect the fan cable 1 from the system board.
4. Remove the four Phillips PM2.5×5.0 screws 2 that secure the fan/heat sink assembly to the system board.
5. Remove the fan/heat sink assembly 3."
To definitely getting this task accomplished, download the service manual from here. It will show you exactly how to do it. Hope this helps, good luck.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 978
