Zum Hauptinhalt wechseln
LG "6 Motion Direct Drive" washing machine released around 2017. Product code FH4G6TDYW2.ABWQWFS.
The washing machine is leaking water
My washing machine always leaks water when washing clothes, and I suffer from that, so what is the solution?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
LG front load Washington 5.5 kg in dripping in water down
von
Einen Kommentar hinzufügen
1 Antwort
01 - LG Washing Machine Drain Pump
The drain pump pumps water out the drain hose. If the drain pump is cracked or damaged, or if the bearings are worn out, the drain pump may leak water. The drain pump is not repairable—if the pump is leaking water, replace it.
02 - LG Washing Machine Hose
Hoses apart from the fill hose or drain hose could be reponsible for a leaking washer. You should inspect all of the appliance's hoses, such as tub-to-pump hoses, for damage or loose connections and replace if necessary.
03 - LG Washing Machine Tub Seal and Bearing Kit
The tub seal might be torn, causing water to leak from the seal. If the tub seal is leaking water, water may leak through the tub seal and into the tub bearings. This can cause the bearings to fail. For this reason, if the tub seal is leaking water, replace both the tub seal and the tub bearings. Be aware that this is a complicated repair and will require disassembling most of the washer.
04 - LG Washing Machine Tub Seal
05 - LG Washing Machine Dispenser Drawer
If a washer is leaking water, you should confirm the dispenser drawer is completely closed and free of damage. If the drawer is cracked, the component could be responsible for the leak and should be replaced.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
قيس الزعبي wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 310
