Zum Hauptinhalt wechseln
Das OnePlus 6T ist ein Android Smartphone von OnePlus. Angekündigt wurde es am 29. Oktober 2018 und erschien dann am 6. November 2018.
Phone is not dash/fast charging + Windows not recognizing USB device
So i cycled back during the rain. The phone didn't get super wet and continued to function but since then does not charge properly. I can charge via USB cable through my PC as it refuses to dash charge via charging brick and the PC will keep giving me warning USB device not recognized.
I have a pair of cables that i have tried it with - so its not the brick or the cables but something to do with the phone me thinks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I would recommend to fully power off your phone, and let it sit for a few hours for it to dry up. Then, turn it back on and it should work again if nothing is damaged.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
This happened about a week ago. So while I can't recollect if I have given it time, but the phone other than the charging is working correctly. I am just trying to identify if replacing the USB charging port will be the apt solution. Because it is charging just not at the fast charge level and not through the brick
von
@nabeelkhan1082, does it even charge at all?
von
Antwort hinzufügen
Nabeel Khan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 292
