Why does my cellphone just vibrate but not turn on?
when i push power botton my cellphone does not working and open only vibrations
Ist dies eine gute Frage?
@lancelenar65523 when you first turn your cellphone on and it vibrates but does not display an image, it is usually because you have a failed LCD. You could try and connect your OPPO to your PC via USB cable and see if you can access it. Otherwise, I would suggest that you start off by replacing the LCD. That will at least rule it out/in as the issue.
To replace your LCD use something like this guide.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
War diese Antwort hilfreich?
Seconded. Although with such little information (@lancelenar65523, more details and info would be helpful), typically when the screen stays black and you have other signs of life, such as noise or vibration, it is a sign of a dead screen. That is the best diagnosis we can likely provide at this point in time.
يهتز لأن الشاشه بها عطل عندما تغير الشاشة سوف يعمل
Translation Arabic - English
It vibrates because the screen is malfunctioning, when you change the screen it will work
Letzte 24 Stunden: 5
Letzte 7 Tage: 25
Letzte 30 Tage: 105
Insgesamt: 4,893
5 Kommentare
HP kalau mati hidupin agak susah
Translation Indonesian - English
If the cellphone turns off, it's a bit difficult to turn it on
von Nyongki zikma
It keeps vibrating even if i dont press the power button
von Francis Yero
@francisyero phones with a broken screen do that. It's a reminder that your screen is broken and it is begging to be replaced.
von oldturkey03
My phone is switched off and not opening
von Firoz Uddin
My phone is showing like restart but still dead
von Ketan
