My computer freezes every 10 seconds and then continues
How can I fix my computer so that it stops freezing every few seconds?
Ist dies eine gute Frage?
To clear up any basic corruption with system files try below:
Run DISM and then SFC from the Command Prompt:
CHKDSK is another Windows system tool that checks your file structure. Unlike SFC, CHKDSK scans your entire drive for errors, whereas SFC scans your Windows system files specifically. Like SFC, run the CHKDSK scan from the Command Prompt to fix your machine.
Are you overclocking? Turn it off.
Run Windows Memory Diagnostics? - Type Windows Memory Diagnostic into your Start menu search bar. Set it to run on next boot.
Let us know how it goes or if you need further help with any of the above procedures.
War diese Antwort hilfreich?
I am going to hook up the monitor and try this today. I'll let you know how it goes. Thank you!
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 49
3 Kommentare
We're going to need more details. Is this a PC you built yourself? Is this a new problem on a freshly built PC or was it fine before this?
von Dany
Thanks for replying! Yes it is custom built. 32gb ram. Win 10. It's no longer connected to a monitor so I can't tell you more, just that it became unusable over a short period of time.
The mouse would freeze every 10 seconds or so and stay stuck for several seconds. Editing, and everything else, become unbearable.
I scanned it with a PC software fixer and eventually reinstalled the OS and essential programs. No luck.
I built it in NYC but I'm in Africa right now and don't have access to the repair shop I would take it to. There are shops here but I'm trying to take care of it myself first.
Any advice is appreciated!
von Larry Lowe
@larrylowe5872
Did this problem occur shortly after you moved to Africa? What power supply are you using? The full spec list of all the components would be helpful.
von Dany
