Zum Hauptinhalt wechseln
Dead laptop, please help
Hi.. please excuse my english. First, I have this laptop, but it's not "touch." I'm sure it's the same model.. and that's not the problem..
My problem is that I bought it used, and then I installed a Windows 11 "clean installation." I did that hundreds of times before. Actually, software things are my hobbies, so I'm sure that Windows installation is done correctly.
After a week of normal to hard using (gaming, multi-tasking, etc...) Suddenly, it freezes while I'm working on something, I pressed the power button for a couple of seconds and then tried to start it again, It started and worked perfectly fine.. after one day, it crashed again, I did the same thing, but it kept crashing after less than five minutes from the start.
I left it for a day and then tried again.. this time, it crashed on Windows booting step and kept doing that several times.
I thought if I reinstalled new Windows, it would be fixed, but when I prepared my booting device and opened the bios setup, I recognized that the pc info (device name, model, ...) are showing "invalid".. well, that's wired cos they appeared correctly the last time I installed windows when I just bought the laptop.
I ignored that "Invalid" thing and prepared the laptop for the windows installation, and then restart it with pressing F12 to display the boot menu but it showed up in a very very slow animation, I didn't like that so I shut it down and started again but this time its dead.. there is a power indication and start indication but no screen at all, not even a blink.
Please Help.. (thanks)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I discovered that its a ransomeware attack..
It converted all my files to .itrz type including system files.. then the pc couldn't work
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Siddeg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 314
