Hi @ephraimschmitt
The compressor should only stop when the set operating temps in the refrigerator and the freezer have been reached or if the refrigerator is in a defrost cycle.
It may take some time to get to the set operating temp of 0°F in the freezer from where it started from
Here's the tech sheet for the refrigerator.
It shows that the compressor is turned on by the control board via an inverter board part # GE WR49X10283, (example only as it has a good view of the board).
It changes the 120V AC supply to 230V supply presumably to conform to the specifications of the compressor.
Are you using the temp displays as shown on the control panel? If so try placing an appropriate thermometer in the freezer compartment and check the temp, in case the display is giving a faulty reading.
If the display temp readings are accurate and the compressor is not operating and it isn't in a defrost cycle, then the problem is either in the inverter board or the control board.
By "flipping the switch" if you meant the power outlet switch then it seems that by doing this it has "reset " the control board and the compressor started again.
It does seem as though it is related to the defrost cycle though. Check if the compressor has stopped for more the 20-25 minutes. This is the approx length of time of a defrost cycle.
You have replaced the defrost thermostat, but all that does is disconnect the defrost heater circuit, so it may be the control board.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
5 Kommentare
Hi @ephraimschmitt,
In the 6 hours is the compressor running continually trying to drive the temp back down to the set operating temp?
Can you hear if the evaporator fan is running when the compressor is running? Usually opening a door (either door) will stop the fan, but the compressor will keep on going. Closing the door will start it again
von jayeff
The freezer is currently at 40 and the fridge at 42. I opened the door to the freezer and the fan is running (open or closed doesn't seem to matter). I cannot tell if the compressor is running. It does not appear to be running though from what I can tell ( a little hard as I don't know if what I am hearing is a compressor or just the loud fan, but appears to be the fan)
von Ephraim Schmitt
@ephraimschmitt
If you can access the compressor you should be able to "feel" it operating (careful it may be hot but it really shouldn't be, warm yes too hot to touch no) although if the condenser fan is also running it is because the refrigerant needs to be cooled which might indicate that it is being pumped through the sealed system.
Do the lights in each compartment go out when you manually operate the door switch with the door open?
Unusual for the evap fan to run with a door open as you don't want cold air being blown out of the either compartment. It is the door switch that signals the control board to turn off the evap fan and also turn on the light(s). The condenser fan if operating will continue to run regardless of the doors being open or shut.
von jayeff
Ok, so the compressor was cold to the touch. The condenser fan was running. And this time when I opened the freezer The evaporator fan was off, but flipping the switch made it sound like the compressor was kicking on and off (sound of pressure releasing each time then something other then the evaporator fan running). Then after a few minutes the evaporator fan kicked in. The evaporator fan does not seem to flip with the open/close switch. But I feel like that is normal for this fridge. It is at 44 degrees now, so I will wait a bit and see if it goes down (now that it sounds like the compressor might be running?)
von Ephraim Schmitt
Just checked an after a hour it is down to 39 degrees and it sounds like the compressor is still running.
von Ephraim Schmitt
