Hi @theproblemmaker
It appears that you're encountering difficulties with your Netis W1 router. Given your description, the router isn't behaving as expected. The fact that only the "WPS" LED initially lights up and the other indicators come on after a delay might indicate a potential issue with the router's startup sequence. However, you're unable to find the router's name in the list of available networks, and you're also unable to access its configuration page via Ethernet.
To address this, there are a few steps you can consider. First, ensure that all cables are securely connected, including the power cable and Ethernet cables. Sometimes, a loose connection can lead to unexpected behavior. If the issue persists, you could attempt a factory reset of the router. Typically, routers have a reset button that can be pressed for a certain duration to restore the router's settings to their default state. Be aware that this action will erase any customized settings you had configured previously.
If these steps don't yield positive results, it might be worth trying a different Ethernet cable and connecting a different device to the router to see if the problem is device-specific. If you can't access the router's configuration page, you might not be able to update the firmware, but if you had access before, it's worth considering if a firmware update might help resolve the issue.
If these troubleshooting steps don't resolve the problem, it's advisable to contact Netis customer support for further assistance. They can provide guidance tailored to your specific router model and help you address the issue effectively.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
