My laptop is not starting
Ist dies eine gute Frage?
We need a little more information in order to help you. For example, what model do you have? Is there any response from the system? Backlight on the display? LED light on the CAPS lock key? Chime on startup? Does the charger make a noise when connected? First try doing an SMC reset or a NVRAM reset. If those don't work, you'll need to consider opening it up to try to diagnose the problem internally. You could try disconnecting and reconnecting the battery. Good luck!
War diese Antwort hilfreich?
HP g series pavillion laptop
OK, you should edit this post so that it has the right associated device. Right now it says "Mac Laptop Overview" which is misleading.
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 23
