Zum Hauptinhalt wechseln
Samsung Galaxy S21 FE (Fan Edition) ist eine Variante des S21 Models, das am 11. Januar 2022 veröffentlicht wurde. Das Gerät hat kleine Veränderungen im Vergleich zum regulären S21, was das Gerät etwas günstiger macht.
Moisture in the port not going away
The notification that there is moisture in the charging port won't go away no matter what I do
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Check that there is no pocket-lint or other debris in the port. Something might be shorting the pins of the port.
You can also try cleaning the port with a toothbrush with some rubbing alcohol on it.
And/or blow on it with some compressed/canned air.
Also, Look into the port with a magnifyer or use phone camera and zoom in, to see if any of the small pins look out of place.
War diese Antwort hilfreich?
Bewertung 0
@jevaughnhenry if cleaning and further drying do not clear up the error, consider a failed sensor on the charging board. Replacing it should resolve this issue. Use something like thios video to replace it. The board is available at many online stores. Just make sure you purchase the board for the right version SM-G990U, SM-G990U1, SM-G990W
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Bewertung 0
Antwort hinzufügen
Jevaughn Henry wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 298
