Why my mic is not working while I am using call?
Mobile mic is not working only while i am using calls. When i use whatsup call it is working very good??
Ist dies eine gute Frage?
@chetanchouhan you want to try a headset and see if that works for your calls. Also, you need to rule out that this is software related. For that check the {https://us.community.samsung.com/t5/Othe... Samsung site] the solution there is for the A14 (SM-A145) but it also applies to the A14 5G (SM-A146)
If you ruled out that this is a software issue, I would suggest that you replace the sub board. The main mic (used for calls) is mounted on that board. Use something like this video to work on it.
The sub-board is available at many places, just make sure that you get one for your phones exact version
Your phone is a relative new phone. Before tearing it apart etc. You want to make sure that you check if you any kind of warranty on it. If so, use it to either get it fixed or replaced.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
War diese Antwort hilfreich?
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 31
Insgesamt: 434
What phone model do you have and the brand
von albertt de jesus diaz
