Zum Hauptinhalt wechseln
Zerlege- und Reparaturanleitungen für die Nespresso CitiZ Kapselmaschine. Sie ist unter verschiedenen Markennamen, z.B. Krups oder DeLonghi erhältlich.
Won’t turn on
Hi, I have a CitiZ and it’s not turning on. Which internal component is likely to be causing the problem? I have an old Magimix I could use some of those parts. Any help would be appreciated. Thank you. Hi, I have a CitiZ and it’s not turning on. Which internal component is likely to be causing the problem? I have an old Magimix I could use some of those parts. Any help would be appreciated. Thank you.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Do you have a model with a dedicated on/off switch on the right side base?
If it's not the power supply/ cable, then it could be the electronics.
In that case, you'd have to check and compare if the PCB of your Magimix (it is a Cititz, too, isn't it?) is identical to your Citiz. As I have seen the order of the connecting cables on the PCB change from model to model.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Georgia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 260
