Zum Hauptinhalt wechseln
Reparaturanleitungen für die 3. Generation des 11" iPad Pro (Modellnummern A2377, A2459, A2301 und A2460).
iPad is bent and screen cracked. I’m scared to bend it back
I want to replace the screen but with it being slightly bent, the new screen wouldn’t go on correctly.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I have repaired many iPads in similar condition before and the metal is actually really easy to bend back in place. I would definitely remove the motherboard and battery very carefully before attempting to bend it back though and should be left to a professional if you haven't disassembled an iPad before. Backup your data before just in case. Once the motherboard and battery are removed then the aluminum shell is easy to bend back into its original shape.
War diese Antwort hilfreich?
Bewertung 2
Yes but I don’t have money repair it
Bewertung 0
1 Kommentar:
I don’t have money to repair it
von
Antwort hinzufügen
Kai wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 1,328
