Zum Hauptinhalt wechseln
A2115 / 2020 / Prozessoren beginnend mit 3,1 GHz 6-Core i5, bis 3,8 GHz 8-Core i7. Markteintritt am 4. August 2020.
Displays an Apple for about 20 seconds and then reboots. Any thoughts
This iMac was brought to me for data recovery after a lightning storm. It powers on and boots straight to an Apple, no status bar, and then sits there for about 20 seconds before silently restarting the process. The iMac A2115 27" 2020 does not respond to wired or wireless keyboard inputs for option boot, target disk mode as well as both internet and non internet recovery and diagnostics. I can zap the PRAM, once, and upon reboot the machine returns to its previous state. It will only reboot once no matter how long option -cmmnd-p-r is held down. The audio, present after the first PRAM reboot, returns to silent for further reboots until PRAM is attempted again. I was successful in getting the mac into DFU mode and was able to revive the software with zero errors, but zero effect. I have pulled RAM and tested with known good RAM and the issue remains. I am at a loss and throwing this out there to see if anyone can help. I'm just trying to get the data off. Cheers!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
The issue is a breakdown in the power circuit. As you are getting power for a short window, this should be recoverable!
You will need to trace out the power lines from the socket to the power supply and then from the PS to the logic board to see if the power is even getting to the logic board in a steady state.
You may also encounter issues within the logic board power rails, again tracing them out.
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
At first I too thought it was power related, but the machine will remain power on in DFU mode for hours, if not days. I even thought about something power related to something further down the POST than what DFU mode requires, but you should still be able to boot into apple's diagnostics and expect it to power down, but it won't even let me in. Thank you for the input. Cheers!
von
@macisaac - DFU mode uses the Intel graphics engine not the AMD Radeon GPU, so it could be focused within the GPU power rails when they are active.
von
That would prevent a low level state such as target disk mode and Apple Diagnostics?
von
@macisaac - Its possible! I've not encountered you exact condition so I can't say.
The fact you got into DFU mode tells me the CPU is working, it may not be under stress of ruing the OS and other stuff so that also holds while you are winking-out as the power to it is not stable. This could be a VRM issue (the power control logic for the CPU) or anything south of it!
This needs someone to trace the power from the AC outlet on the back of the system to the logic board to see if the PS is the issue and then picking it up at the logic board tracing out the power rails.
von
Same issue, any help??
Bewertung 0
8 Kommentare:
@huachomartin - Start with the basics:
- Check your outlets are properly wired and grounded
- Did you run the onboard Diagnostics? Any errors.
- Are you running any thermal monitoring App like TG Pro which I find is one of the best out there. Are you noticing a pint in time under stress the system fails? - What happens if you ramp up the cooling does it take longer to wink out?
- What are you running when it fails?
- How much RAM does the system have? If you have 16GB take out one Bank is that better? If not swapout the set with the other (hint mark then so you don’t confuse your self).
- How big is your drive? What is it and how full is it.
von
Thanks for ur reply!
I have done everything, power supply, configurator, inspected logic board and still same issue :(
Same isaue than @macisaac
von
@huachomartin - How about going down the list I gave you, what does the onboard diagnostics tell you? As well as answer the other questions. Can’t offer you an answer without input.
von
It wont respond to any keyboard combination (cmd-r, D, safe mode, alt, PRAM)
von
@huachomartin - Do you have a USB keyboard? Give that a try.
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
macisaac wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 22
Insgesamt: 428
