Zum Hauptinhalt wechseln
Der Dell Inspiron 15 5000 Laptop besitzt ein 15,6 Zoll LCD-Display.
How to check power socket
while powring on with wire its not showing power on anp pressing hard its getting charged
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @amitvirani
Here's the service manual for the laptop.
Go to p.79 to view the procedure to remove/replace the power adapter port.
You only have to dis-assemble the laptop far enough so that you can safely unplug the port's output cable from the motherboard.
Once that is done use an Ohmmeter (or a voltmeter), to prove continuity of the connection between the port input and the red and black wires on the cable plug on the output side of the port.
If the port is faulty it cannot be repaired. It has to be replaced.
Search online for KD4T9 to find suppliers that suit you best.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Amit Virani wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 215
