My ps3 is on but its snowing no signal
My ps3 is on but its showing no signal
Ist dies eine gute Frage?
Hi, your PS3 might be trying to output to analog. Try doing this:
Turn off your PS3. Now press and HOLD the 'On' button on the PS3 itself (not on the controller). It will beep and reset the connection type. I believe it will use HDMI if available, if not then it'll switch to AV.
Also make sure the HDMI cable or AV cable your using is working. Maybe your TV/Monitor is set to the wrong input (which is unlikely but may happen, sometimes the fix is easy like that)
I hope this works for you.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 42
