Zum Hauptinhalt wechseln
iMac Intel 27" EMC 2309 (Ende 2009, Core 2 Duo 3.06 oder 3.33 GHz) ID iMac10,1, EMC 2374 (Ende 2009, Core i5 2.66 GHz oder Core i7 2.8 GHz) ID iMac11,1
Backlight shutting down randomly after gpu replacement
Hello together!
I have replaced the GPU due to a GPU error (no boot only in safe mode and then with horizontal stripes at the cursor).
Everything worked fine for a few hours, but now the backlight of the LCD goes off at random intervals (LCD works, but no backlight).
I now opened everything again and saw that the Vsync flex cable is damaged (pins broken) probably I was too rough during disassembly....
Can I now simply replace the cable and everything works again or is more defective?
If I do not connect the cable the error remains unfortunately...
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I would start there, is the sockets damaged?
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
No it seems to be okay
von
Antwort hinzufügen
Valentino wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 118
