Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für die Apple Time Capsule Modell A1302, im Wesentlichen auch gültig für das Modell A1254.
Is it possible to install an 8TB hdd?
I have a 2009 Time Capsule with the 1TB HDD and I am wondering if I can upgrade the HDD to 8TB or if there is a capacity limit? It seems like there is conflicting information where some have reported that there is a 3TB limit while others have said there is no (feasible) limit. I don't want to waste money on something that isn’t compatible. I am aware of the SATA II limitation. Thank you for your help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The different series of the Time Capsule have different limits. The first three versions if I remember correctly are 3TB. The fourth and fifth can be boosted 6TB as that is what I had done. You maybe able to go higher.
Make sure the drive fully supports SATA II systems, many don’t.
Wikipedia - Time Capsule specs
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks Dan. So I guess my 2009 2nd gen can only go to 3TB. Still plenty enough for me I guess.
von
Antwort hinzufügen
Duck wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 46
Insgesamt: 491
