Zum Hauptinhalt wechseln
Reparaturinformationen und Fehlerbehebung für den Dell Inspiron 15R N5010 Laptop-Computer.
5 Fragen Alle anzeigen
Display driver has stopped and recovered
The screen will be while log on.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The error message "Display driver has stopped and recovered" means that the graphics driver on your computer has crashed and then recovered. This can happen for a number of reasons, such as:
  • Outdated or corrupted graphics driver
  • Incompatible graphics driver
  • Overheating graphics card
  • Hardware failure
If you are seeing this error message, there are a few things you can try to fix it:
Run a diagnostic tool
To run a diagnostic tool, you will need to download and install the program from the manufacturer's website. Once the program is installed, launch it and follow the on-screen instructions to test your computer hardware.
If the diagnostic tool finds any problems with your computer hardware, it will display an error message. You can then use the information from the error message to troubleshoot the problem or replace the faulty hardware.
Here are some examples of diagnostic tools:
  • MemTest86: MemTest86 is a memory diagnostic tool that can be used to test your computer's RAM for errors.
  • Prime95: Prime95 is a CPU stress test tool that can be used to test your computer's CPU for stability.
  • CrystalDiskInfo: CrystalDiskInfo is a hard drive diagnostic tool that can be used to monitor the health and performance of your hard drive.
  • FurMark: FurMark is a graphics card stress test tool that can be used to test your computer's graphics card for stability.
It is important to note that diagnostic tools can put a lot of stress on your computer hardware. It is important to monitor your computer's temperature while running a diagnostic tool and to stop the test if your computer starts to overheat.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Santhanamuthu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 83
