Zum Hauptinhalt wechseln
Phone internal memory full
What should be the solution
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Saya juga mengalami ponsel perangkat penuh
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hi @adewuyiadebayo
To increase the storage in the phone insert a micro SD card (up to 512GB capacity) into the phone and then move your apps/personal data etc from the internal storage to the SD card.
Here's an image that shows how to insert/remove and format the SD card that may help.
(click on image)
Here's the user manual for the phone that may also help.
War diese Antwort hilfreich?
Bewertung 2
My first suggestion is to delete any apps that you don't use. If that doesn't lower it, then go to your settings and navigate to battery and device care. Once inside, click on storage it will show you a breakdown of what is taking up most of your storage. Now, the next thing to do is start cleaning out your storage by going to each problem spot and start deleting any unnecessary files and/or apps. Hopes this helps!
Bewertung 1
Clear unwanted and old files every 6month please do software reset
Bewertung 0
Antwort hinzufügen
ADEWUYI ADEBAYO wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 506
