Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
my car won't run - what is the problem???? Without more info, it can be hundreds of things. Give us some clues. What do you do? What happens when you do it? What do you hear? Is the car up to temp?...................
@kapil85503 consider rephrasing your question. We need to know the year and model of your car. We need to know what is not working, things like is the fan working, does it turn on, does it just not heat etc. We also need to know what you have checked. We can’t help you unless you help us to understand what is going on with your Suzuki.
Car heater is not working
von Kapil
@kapil85503 Did you check to make sure that none of the fuses were blown?
von Andrew S
von bill
von oldturkey03
