Zum Hauptinhalt wechseln
24-Zoll-Display; Integrierte iSight-Kamera, Mikrofon und Lautsprecher; 1920x1200 Auflösung. Erschienen im Oktober 2008, identifizierbar durch die Modellnummer A1267.
I have two displays with weird display images!
Anyone know if this is fixable I have 2 Cinema screen monitors that are this way.
Does not appear when the monitor is off. Only after it's turned on. Should I just chuck them?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Ouch! What you are seeing is the breakdown of the liquid crystal material that is sandwiched between the two sheets of glass that makes up the panel.
These displays are still highly sought! Just for there well designed and constructed. You can still buy a replacement panel for them which would be cheaper than replacing.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
MIlagros Ramos wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 233
