My black E7 headphones won't play any sounds
The lights turn on but it won't play any sound
Ist dies eine gute Frage?
Hello, after doing some searching, I've found that it may be a bluetooth connection issue. What this means is more than likely an issue with the device you're trying to connect to instead of the headphones. I would recommend checking if all your software is up to date or a simple reset should do. If the problem persists, then I would recommend following this troubleshooting guide. I hope this helps!
War diese Antwort hilfreich?
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 16
Insgesamt: 75
