I'm glad you replaced your screen and battery of your iPhone XS, but I'm sorry to hear that you have problems with your charging port. Im sorry for not getting back to you sooner as i am quite busy these days but my AI has prepared an answer for you:
If your charging port is damaged or faulty, it can cause loop errors, which means your device will keep asking you to connect to iTunes even though you have already done so. This can be very frustrating and prevent you from using your device normally.
To ensure that your replacement charging port is good quality, you should follow some tips and precautions. First of all, you should always buy a genuine or high-quality aftermarket charging port that is compatible with your iPhone XS model. You can find such parts online or at reputable repair shops. You should avoid cheap or low-quality parts that may not work properly or damage your device further. You can check the reviews and ratings of the parts before buying them, or ask for recommendations from other users or experts.
Secondly, you should follow a detailed and accurate repair guide to replace your charging port safely and correctly. Replacing the charging port is not an easy task, as it involves removing many components and screws, and disconnecting many cables and connectors. You should have the right tools and skills to perform this repair, or seek professional help if you are not confident. You should also be careful not to damage any other parts or components during the repair, such as the screen, the battery, the logic board, or the cameras.
I have searched the web for some useful resources that can help you with your charging port replacement. You can watch some video tutorials that show you how to replace the charging port step by step, such as [iPhone XS Charging Port Replacement - Tutorial](^1^), [iPhone XS Charging Port Flex Replacement | Logic Board](^2^), or [How to replace iPhone XS charging port - walkthrough](^3^). You can also read some written guides that provide detailed instructions and pictures, such as [iPhone X Lightning Connector Replacement - iFixit Repair Guide](^4^) or [iPhone Xs Lightning connector repair guide | iDoc](^5^). These guides also tell you what tools and parts you need for the repair.
I hope this information helps you to replace your charging port successfully and fix your loop errors. If you have any questions or issues, please feel free to contact me again. I'm always happy to help. 😊
Source: Conversation with Bing, 10/5/2023
(1) iPhone XS Charging Port Replacement - Tutorial - YouTube. https://www.youtube.com/watch?v=ZM8mAHiy....
(2) iPhone XS Charging Port Flex Replacement | Logic Board. https://www.youtube.com/watch?v=Ac93syG3....
(3) How to replace iPhone XS charging port - walkthrough. https://www.youtube.com/watch?v=EKgFCKaB....
(4) iPhone X Lightning Connector Replacement - iFixit Repair Guide. iPhone X Lightning Anschluss tauschen.
(5) iPhone Xs Lightning connector repair guide | iDoc. https://www.idoc.eu/guides/en/apple/ipho....
(6) undefined. https://www.amazon.com/shop/sandiegoipho....
(7) undefined. https://zegsu.com/s/djj2k.
(8) undefined. https://witrigs.com/ef7my.
(9) undefined. https://zegsu.com/s/dj2cm.
(10) undefined. https://zegsu.com/s/dj437.
(11) undefined. https://zegsu.com/s/dj40x.
(12) undefined. https://zegsu.com/s/dj17d.
(13) undefined. https://zegsu.com/s/dj18b.
(14) undefined. https://zegsu.com/s/dj4xi.
(15) undefined. https://business.facebook.com/witrigs.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
@kingofspades
1) Ok thanks. I think I found it? Scroll up to my first post, i added the photo there from the video.
2) How do I know if the lightning port I have is good quality and won't cause the loop? I'm on ios 12.4 still and love it. I'm been afraid to update. If I take pics of it would that tell you, or if I find a link to it and paste it? Thanks!
von Jason
