Zum Hauptinhalt wechseln
Repair guides and disassembly information for Honor's Android-based smartphones. Get everything you need to repair your Honor phone yourself.
Why my phone stuck in logo
phone power on but stuck in logo
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
If your Honor phone is stuck on the logo screen when turning it on, it could be due to several reasons. Here are some common causes and steps you can take to try and resolve the issue:
Software Glitch or Crash: Sometimes, the phone's software can encounter a glitch or crash during startup. To address this, try the following:
Force Restart: Depending on your Honor phone model, you can perform a force restart by pressing and holding down the power button and volume down button simultaneously for about 10-15 seconds. This should force a reboot and might help resolve the issue.
Low Battery: Ensure that your phone has enough battery charge. If the battery is critically low, the phone might not start up properly. Plug it into a charger for a while and try turning it on again.
Corrupted System Files: If there was an issue with a recent software update or if system files are corrupted, you may need to perform a factory reset. Keep in mind that this will erase all data on your phone, so it's important to have a backup if possible.
To perform a factory reset, you can often access the recovery mode by holding specific button combinations (usually power button + volume up or down) when turning on the phone. From there, you can navigate to the "Factory Reset" option.
Hardware Issues: If none of the above solutions work, it's possible that there is a hardware problem with your phone. This could be related to the motherboard, storage, or other components. In such cases, it's best to contact Honor's customer support or visit a professional technician for a diagnosis and repair.
Bootloop: A bootloop occurs when the phone repeatedly restarts and gets stuck on the logo screen. This can be caused by various factors, including incompatible apps or a failed software update. You may need to enter recovery mode (if available on your device) and wipe the cache partition or perform a factory reset to break the bootloop.
Firmware Update: Check if there is an official firmware update or software patch available for your Honor phone. Sometimes, manufacturers release updates to address known issues or bugs that can cause startup problems.
If you've tried all the above steps and your Honor phone is still stuck on the logo screen, it's advisable to contact Honor's official support or visit an authorized service center for further assistance. They can provide specific troubleshooting steps or offer repair services if necessary.
War diese Antwort hilfreich?
Bewertung 0
I want to switch the screen
Bewertung 0
Antwort hinzufügen
gdmobile wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 40
Letzte 30 Tage: 106
Insgesamt: 2,128
