Zum Hauptinhalt wechseln
The second generation Integra was introduced in April 1989 and in this generation, one of the first VTEC engines ever manufactured by Honda was installed in a JDM Integra DA series.
I have no spark and no fuel pump prime
Car had bad wiring before and figuring it all out. Main relay was tested= good, fuses were tested= good, fuel pump was tested=good, the distributor is brand new along with the spark plugs and wires. Grounds are good to the battery terminal/transmission , thermostat housing, and valve cover. Car dash lights come on and car cranks. Check engine light stays on, I get no codes thrown when tried to flash for codes.
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Would that be the same for a 93? Sorry just making sure
von
@oniichanz
Yes is is for years 1990-1993
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @oniichanz
Here are some images from the 1990 Acura Integra repair manual showing the ignition circuit and the fuel pump circuit, that may help.
(click on image)
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Onii Chanz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 35
Insgesamt: 558
