Zum Hauptinhalt wechseln
Repair and disassembly guides for electronic keyboards.
20 Fragen Alle anzeigen
Yamaha psr e343 battery port change
I opened my keyboard after a long time like years and I had the batteries inside it too, so now all the batteries are rushed and the whole battery port is ruined. I did try starting up the keyboard with charger and it lights up but only when I keep pressing the ON button, so I think everything is good it just needs a repair on the battery port.
I needed to know from where to buy this battery port too.
Thanks!!!!!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I think you may struggle to buy just the battery port but if you manage to pry it out you could clean it with rust remover and a wire brush and restore it to a good condition. These parts are normally just some nickel coated plates and springs.
I would try to carefully pry them out of their socket (might need to take them out from the underside though) and then soak them in rust remover, then give them a good scrub with a wire brush. Sometimes you can use finer grit sandpaper to remove the corrosion.
War diese Antwort hilfreich?
Bewertung 2
@mohitjoshi31517 you can replace the spring terminals from battery assembly, but like @honakrisi already alluded to, it's a PITA however, it is possible. Page 17
from the SM PSR E343 Removing it might help you to clean it and possibly restore it. BTW I am a strong believer in Citric Acid as a rust remover. It's considered non-toxic and safer for the environment than most commercially available products
Bewertung 0
Antwort hinzufügen
Mohit Joshi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 95
