Zum Hauptinhalt wechseln
The HP Chromebook 14 G4 features a 14-inch HD display and is only 0.7-inch thick. A Chromebook is a laptop or tablet running the Linux-based Chrome operating system.
Does anyone know what size screws these use?
I bought a used one and was taking it apart to remove the write protection screw and I noticed a very mangled heatsink with a stripped screw and a hp service sticker. Most of the screws in this machine have been stripped and I wondered if anyone knew the sizes. I would prefer to buy a laptop screw kit (pictured below) or just screws rather than a pricey genuine replacement screw kit as I have multiple of these.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@ajzimmermann here is the service manual HP Chromebook 14 G4 SM that should work for your computer. Each component listed for removal has the proper screw thread diameter and length listed. i.e. the bottom case has 13 M2.0 x 5 mm in length
Yes, it's a bit of work but at least you can determine exactly which screws you will need.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
AJ Zimmermann wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 595
