Why is my phone ink always spread on my screen?
My phone has a small ink on the screen but every day out it starts spreading. What should I do to stop the ink from spreading?
Ist dies eine gute Frage?
@benjaminanaman your phone has an AMOLED. Display. When these crack they leak. The only way to repair this is by replacing the screen.
Since iFixit does not yet have a guide for this, use something like this video to replace the display. Replacement displays are available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
War diese Antwort hilfreich?
Well it usually means your phone's display panel is damaged, likely from a drop or impact on your phone screen which causing the liquid crystals inside to leak and spread. So I will suggest you to fix your phone display it can cause more damage to you phone display.
Your phone screen likely has internal damage, causing the "ink" (LCD liquid or pixels) to spread. This happens due to pressure, heat, or further cracks. To prevent more damage, avoid pressing on the screen, use a screen protector, and get it repaired or replaced as soon as possible.
My Pura70 fell and have the line inside not in the screen
@tsakanimashaba your phone has an AMOLED display. When these crack they leak. The only way to repair this is by replacing the screen.
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 134
Insgesamt: 4,024
5 Kommentare
My phone in Infinix note 10 pro max my problem is pone has automatically black line in this screen
von Infinix note 10 pro max
@infinixnote5092
See the Most Helpful Answer below for what to do.
von jayeff
von Jane
@jane21237, out of curiosity, what is your point in copying the exact question and posting it as an answer? You could simply say you have the same problem; that way you won't look so much like a troll or a spammer.
Anyway, if you are seriously asking, the question has already been answered authoritatively; see the Most Helpful Answer if you really want to know.
von Jerry Wheeler
Charging problem
von Dipak Dey
