Zum Hauptinhalt wechseln
{A1989 / EMC3214}—Erschienen im Juli 2018. Das 13" MacBook Pro ist mit Quad-Core i5 und i7 Prozessoren und Intel Iris Plus integrierter Grafik ausgestattet.
Bad battery or bad board?
Looking at this MacBook, It's the Late 2018 model w/4 thunderbolt ports. Nothing I can do will get it to start. None of the key combos work. I have tried disconnecting the battery and plugging it in, and still nothing. Is it supposed to be able to turn on with the battery unplugged?
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare:
The laptop should power on with the power chord. Does it make any noise when plugging it in? Does the fan turn on?
von
@mike_ohmstede No, nothing at all happens and nothing responds to any input
von
@the_horak
How many watts for the charger
von
According to Apple, it should be a 61W USB-C Power Adapter. I've charged other apples with less wattage with it completely turned off and the lid closed.
https://support.apple.com/kb/SP775?local...
von
@mike_ohmstede probably the motherboard died
von
Einen Kommentar hinzufügen
1 Antwort
I am pretty sure it is an SSD failure. As on the TBMPBs used a T2 chip, the Mac would be unable to boot, even post with any NAND chips not working, which in turn, makes the board not functional. I am not 100% sure on this, but it is quite likely as this would happen if a single NAND chip died due to the RAID configuration and the way the Bootloader is stored. Hope this helped.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Mark Student wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 152
