Zum Hauptinhalt wechseln
A gaming PC is a personal computer specifically designed and optimized for playing video games.
pc randomly turning off, but working good when it turns on
Hello, my pc randomly turns off while starting, sometimes 1 time sometimes twice, but after that when it starts it works perfectly, on 100% on idle its working perfectly, what can be the issue. temps on load about 65 degree.
cpu: ryzen 7 5800x
gpu: rx580
mbo: b550 gigabyte
ram: corsair 3600mhz 32gb
psu: cooler master 750W 80+
cooling: bequiet silent loop 2
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
First of all which model of the Gigabyte B550 do you have? There are at least 12 of them?
Did you notice anything in particular that happened before the shutting down started? Windows or driver updates, browsing a dodgy web site, emails, etc.?
Well it is not overheating so that is good. It could be a hardware problem or a software problem
As there are many possible causes of your problem I recommend keeping a journal or a check list of what you try so you don't get lost. Believe me it is easy to forget what you have tried.
Hardware:
  • Try going into the BIOS/UEFI and just leave it on for a while to see if it still randomly shuts down. If it does then it is likely a hardware problem.
  • Faulty hardware - try isolating the problem by removing one component at a time, with the power shut off such as HDD/SSD/NVMe, Wifi card, graphics card (I believe all the B550 models have onboard graphics)
Windows:
  1. Click on Windows Event Viewer which will enable you to view the date, time and user details of all shutdown events caused by a shut down (power off) or restart.
  2. Use, with Administrator privilages, DISM command to repair Windows' images and SFC command to check for corrupt system files. Look up to learn how to use with the CMD prompt or use a tool like this that does it automatically for you (click here) .
  3. Look in the Device Manager to sea if any device have the exclaimation mark indicating driver problems
  4. Updating all drivers and Windows or rolling a recent one back.
  5. A full viruse and malware scan would be a good idea.
  6. Sometimes enabling "Fast Startup" has been known to cause random shutdowns. try Turning it off.
There are other possible causes and solutions such as intermittant power supply or mainboard problems. The above should be enough for now to keep you busy.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
mbo: is gigabyte b550 gaming x v2, the thing i did before this started is i changed my ram, i also ran a ram scan but there everything seems fine.. it would also crash in bios but after it starts it works perfectly
von
@lurixxxx
Can you reinstall the original ram and check if the problem is still there or not?
Maybe an idea that seems crazy but remove the coin cell battery from the motherboard and measure its voltage. If it is <2.2V DC replace it and check if the problem still happens. You will have to reset the date and time and also any user definable BIOS settings that you had changed to suit whatever configuration you had.
Disconnect the power to the PSU before you remove/reinsert or replace the battery
von
@jayeff will do as soon as I get home
von
@lurixxxx
Just some thoughts.
I am not saying you did this but I have come across clients who broke traces on their mainboard while taking out and inserting RAM.
Is the new RAM on the Gigabyte list for your model b550 gaming x v2 ? You left out the Rev. version of either Rev. 1.0, 1.1, 1.2, 1.3 or 1.4. Also note they suggest different CPU's with different RAM as on this page https://www.gigabyte.com/Motherboard/B55...
von
It may bem overheating wich may cause it to shut down
Bewertung 0
Antwort hinzufügen
Lurixxxx wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 709
