Repair guides for the Portacool Cyclone 130, an evaporative cooling fan with model number PACCY130GA1 or just PACCY130. This fan was released in 2019, and is part of the Cyclone series of Portacool fans.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar:
Most fans use plain bearings described as sintered bronze with permanent lubrication. However, plain bearings sometimes need oil lubrication. if you can clean off debris and have access to both bearings, try some light oil and spin the fan. If oil seeps into the bearing, the fan should turn freely.
von F Dryer
