Zum Hauptinhalt wechseln
Repair guides and support for the Galaxy Tab S6, released in August 2019. Model number: SM-T860NZAAXAR
20 Fragen Alle anzeigen
Where could I get a replacement internal display?
The outer glass is fine, but the actual display is cracked and completely cooked; the tablet vibrates, but nothing on the screen shows up. The only display replacement I found was $335, surely there has to be a more affordable option?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@mistermemer your display is fused together with things like the touchscreen etc. So your optiglass may still be okay but the LED screen has obviously failed. Since they are fused, you would be looking at a complete display assembly. Your display is an AMOLED screen and yes, those are expensive. You can opt for a used one from places like ebay or some LCD screens from Aliexpress which go for around ~USD$200 etc. but otherwise you are looking at the USD$300+ range.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jason Q. wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 115
