Why did my phone shut down after entering water?
My iphone 7 entered water since it had some cracks and eventually shutdown.So why did the phone shutdown?And some remedies
Ist dies eine gute Frage?
Hi Josephine,
Water damage in a phone is a tricky thing, as you can never tell exactly what will be affected nor how badly.
Batteries and screens are the parts that seem to take the most damage from getting wet, so we usually advise you to first clean the phone. That means opening it up and rinsing/cleaning with 90% or higher concentration isopropyl (rubbing) alcohol. This will displace the water and reduce the risk of electronics-destroying corrosion. This guide is made for older iPhones, but is just as applicable to yours.
iPhone Liquid Damage Repair - iFixit Repair Guide
And please, for the love of god, do NOT put it in rice! That's a myth and won't do a darn thing but make sure the water stays in your phone longer, along with getting contaminants from the rice in every hole in the phone.
Once you've gotten the phone cleaned up, first thing to do is replace the battery then see where you are. If it seems to be alive but you don't see anything on the screen, chances are the screen is also shot and would need to be replaced.
Use the guides under your device page to open the phone and replace the parts as needed. Following these instructions will give you the best chance of getting your phone through this still alive.
If you don't feel confident of your abilities in this area, then you need to seek out a repair shop that's experienced with liquid damage immediately. The longer you wait the more chance you phone will suffer unrepairable corrosion damage and may end up toast. The sooner you address the issue, the better your chances to save the phone.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 30
