Zum Hauptinhalt wechseln
A security and intelligent doorbell that live streams 24/7 and notifies you if someone is at your door.
Where to find replacement gasket?
Where can one find the replacement gasket?
The replacement of this piece is mentioned in its own guide as well as in the battery replacement guide. I have not been able to find with basic search terms.
Thank you in advance!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @kb_kb
If you can't find a replacement gasket, you may have to improvise.
Try either a suitably sized elastic rubber band or perhaps run a thin bead of neutral cure silicone sealant around the case in place of the gasket.
If using the sealant and you need to open the case in the future use either vinegar or Isopropyl Alcohol to soften it first and then pry open the case.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
KB_KB wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 154
